tranny question
Old Dec 1, 2012 | 01:37 PM
rocket350's Avatar
1970 olds cutlass supreme
tranny question
i have a 1970 cutlass 350, it was sitting for 15+ yrs, i got it running, just changed plugs, oil, wires, and distributor cap.
i had the front jacked up to change spark plugs on pass side, i accidentally lowered tire on my hat, so i decided to just start it up and move it a foot.
i shifted to drive, and reverse, hit the gas and it wouldn't move. only rolled backwards because of hill its on.
my question is, with these older cars does the engine and tranny have to warm up before it will go?
also i checked the rear diff before, and the gears seemed to be ok. checked it by lifting up rear off ground and manually rotating tires by hand.
Old Dec 1, 2012 | 01:48 PM
Let it warm up and make sure the trans is full. Also make sure the detent cable moves freely.
Old Dec 1, 2012 | 03:00 PM
rocket350's Avatar
detent cable, u mean shifter cable right?
Old Dec 1, 2012 | 04:11 PM
No I meant the one that runs from the carb to the trans, you stated it was a 350 trans, right.
Old Dec 1, 2012 | 05:02 PM
rocket350's Avatar
i dont know, i havent read up on the car yet, all i know is
its a 1970 cutlass, with a rocket 350 engine, should be all stock
Old Dec 1, 2012 | 06:12 PM
tru-blue 442's Avatar
Old School Olds
The detent cable or "kickdown cable" goes down at the bottom of the tranny
beside the filler tube and is held down by a 5/16 bolt. It takes a 3/8
wrench or socket to remove the bolt. Be careful, over the years they
can become brittle. There is an o-ring over it that can go bad over time
and could have leaked fluid out there. Or the rear seal or the front seal...
Sounds like it is just low of tranny fluid. as has been stated, warm it up
and make sure it's full. Post your results.
butchashop
Jun 15, 2010 05:48 AM
dhartley72
Mar 24, 2010 02:27 PM
JMW803
Mar 16, 2010 05:07 PM
fred franklin
Jan 4, 2010 12:23 PM
pappy86
Oct 17, 2009 01:36 PM
