Thinking about transmission rebuild..
Old July 18th, 2015, 10:24 AM
Copper Nine Eight's Avatar
1985 delta 88
So I'm thinking about trying to rebuild my automatic transmission myself. I'm no mechanic but Im somewhat handy. And my friend who is a mechanic is going to help.
Anybody out there have experience rebuilding transmission? It has overdrive, Idk if that makes a rebuild any different. Is there any special tools I would need? And is there a manual or something available for that? Im pretty scared about doing it but I want to be able to say that I can rebuild a transmission! And is there a kit or something with all the parts to do the rebuild? If so, where do you guys recommend I get it from? THANKS!
Copper Nine Eight is offline
Old July 18th, 2015, 11:16 AM
Originally Posted by WB8588
1985 delta 88
I'm assuming your 85 has a 200-4R? If so, this is probably not a project for the first-time trans rebuilder. The 200-4R requires some specialized tools or else special techniques to get around using the factory tools. If you have your heart set on it, I would spend the $80 and buy the 200-4R rebuild and modification manual from CKPerfromance. This will give you a much better idea of both the effort involved and the techniques and tools required for this particular trans.
joe_padavano is offline
Old July 18th, 2015, 03:38 PM
Thanks man! My heart is really set on it
Old July 18th, 2015, 04:06 PM
Octania's Avatar
read the procedure first
I have done some like that, ended up taking quite a while to make the various special tools required to compress the clutch packs &c., then I ended up nicking a seal ring which has to be convinced in against the lip with a loop of music wire, and I had to remove the trans from the car again and put another seals kit in. Into all the clutches.
Octania is offline
Old July 18th, 2015, 04:10 PM
I plan on going into the job, level minded. Read the procedure's first and stuff.. but you know how it gets and you get all excited and just want to start working.
Old July 21st, 2015, 05:21 PM
TexasT's Avatar
I'm kinda handy too, and I assembled a 2004r as my first(and only so far) trans build. As above, get the ck book. Also might look into an atsg manual. I kind of pieced a "kit" together, and bought from several suppliers. If you want to one stop shop it I would call David Husek at turbobuick perdormance. He will put together a comprehansive kit and provide service after the sale.
I think it is much easier with the low/rev tool but know of many who did without. Compressing clutch Pack I did with a hydraulic press but there are other ways.
I say go for it.
https://classicoldsmobile.com/forums/transmission/94130-200-4r-rebuild.html
TexasT is offline
Old July 21st, 2015, 05:54 PM
Professur's Avatar
http://gnttype.org/forums/showthread.php?t=9724
Professur is offline
jensenracing77
January 12th, 2016 02:02 PM
63super88
March 3rd, 2014 06:56 PM
442dreamer
August 23rd, 2011 07:28 AM
Gary's 2 442-S
August 14th, 2011 12:04 PM
442oldslawyer
April 29th, 2010 09:22 PM
Quick Reply: Thinking about transmission rebuild..
