Shifter/cable question
Old Jul 28, 2012 | 06:33 AM
Guttermouth's Avatar
Hi guys, (71 cutlass supreme 455cid th400, center console)
My shifter cable broke yesterday, and i got it out of the car just now.
I always wanted a new shifter too because I don't really like how you have to pull up the T on the original shifter.
So I was looking around a bit and the hurst duall gate shifter really got my attention, a bit too expensive though but nice non the less. But I also understand that the center console needs some cutting in order to fit it?
also wanted to know if I needed any special mounting brackets to install it?
So this is what I need?
http://www.opgi.com/p/transmission/2...0/CT20053.html (shifter)
http://www.opgi.com/p/transmission/1...0/C240557.html (bracket)
http://www.opgi.com/p/interior-trim/...4/C240878.html (cable)
Last question, Are there any nice alternatives for the shifter? cause the duall gate is really expensive. I also would like something that works really good with the center console.
This is my center console:
http://i1206.photobucket.com/albums/...s/IMG_1886.jpg
Thnx in advance,
Clint
Old Jul 28, 2012 | 06:58 AM
Doomah's Avatar
You also need your neutral safety switch
http://www.opgi.com/p/interior-elect...2/1994235.html
I think this is the right one for the shifter you are looking at.
Old Jul 30, 2012 | 06:58 AM
Ok guys,
I've decided to go with the hurst v matic 2 shifter and make it so that my console accepts it like this guy did: https://classicoldsmobile.com/forums...extra-gear.jpg
The kit also comes with a cable and neutral/reverse switch so no worries about that either.
-Clint
defiant1
Feb 4, 2020 08:53 PM
nitrovette
Aug 12, 2014 04:15 PM
rootney
Jun 27, 2014 11:30 AM
dmberendsen
Apr 10, 2013 03:18 PM
weasel
Feb 8, 2011 07:36 PM
