Knocking sound under shifter
Old January 29th, 2015, 11:31 PM
Bluedane's Avatar
Ok so i dropped into 1st gear and a high pitch knocking sound started right under the floor shifter. It goes away after driving but comes back occasionally, especially when i turn right corners. Any thoughts what this might be? Cheap and easy-to-fix answers only please!
Bluedane is offline
Old January 30th, 2015, 06:26 AM
Originally Posted by Bluedane
... Any thoughts what this might be? Cheap and easy-to-fix answers only please!
Turn up your radio until you can't hear it.
Time to do a bit more troubleshooting, could be as simple as a ujoint or trans mount.
oldcutlass is offline
Old January 30th, 2015, 07:12 AM
same but different
don71's Avatar
Shift linkage touching the exhaust pipe?
don71 is online now
Old January 30th, 2015, 07:47 AM
boese1978's Avatar
Loose trans mount bolts?
boese1978 is offline
Old January 30th, 2015, 07:54 AM
Kjr442
kjr442's Avatar
I had one that had a bent transmission crossmember. Somehow the crossmember had been bent upwards, thus making the input shaft hit the bottom of the car, but only if I hit a dip in the road. Having more then one person in the car also made a difference.
kjr442 is offline
biggus
March 20th, 2015 12:06 AM
Joffroi
April 7th, 2014 05:27 PM
plonka
November 17th, 2013 02:57 PM
OCM
January 29th, 2011 01:30 PM
veltboy618
March 16th, 2009 07:31 AM
Quick Reply: Knocking sound under shifter
