Knocking sound under shifter
Old Jan 29, 2015 | 11:31 PM
Bluedane's Avatar
Ok so i dropped into 1st gear and a high pitch knocking sound started right under the floor shifter. It goes away after driving but comes back occasionally, especially when i turn right corners. Any thoughts what this might be? Cheap and easy-to-fix answers only please!
Old Jan 30, 2015 | 06:26 AM
Originally Posted by Bluedane
... Any thoughts what this might be? Cheap and easy-to-fix answers only please!
Turn up your radio until you can't hear it.
Time to do a bit more troubleshooting, could be as simple as a ujoint or trans mount.
Old Jan 30, 2015 | 07:12 AM
don71's Avatar
same but different
Shift linkage touching the exhaust pipe?
Old Jan 30, 2015 | 07:47 AM
boese1978's Avatar
Loose trans mount bolts?
Old Jan 30, 2015 | 07:54 AM
kjr442's Avatar
Kjr442
I had one that had a bent transmission crossmember. Somehow the crossmember had been bent upwards, thus making the input shaft hit the bottom of the car, but only if I hit a dip in the road. Having more then one person in the car also made a difference.
biggus
Mar 20, 2015 12:06 AM
Joffroi
Apr 7, 2014 05:27 PM
plonka
Nov 17, 2013 02:57 PM
OCM
Jan 29, 2011 01:30 PM
veltboy618
Mar 16, 2009 07:31 AM
