Knocking sound under shifter
Ok so i dropped into 1st gear and a high pitch knocking sound started right under the floor shifter. It goes away after driving but comes back occasionally, especially when i turn right corners. Any thoughts what this might be? Cheap and easy-to-fix answers only please!
I had one that had a bent transmission crossmember. Somehow the crossmember had been bent upwards, thus making the input shaft hit the bottom of the car, but only if I hit a dip in the road. Having more then one person in the car also made a difference.
