Dual Gate shifter, how does it work?
Old October 27th, 2014, 09:32 AM
bundy's Avatar
Just got my 71 SX back from the body shop and starting to toy with it.
It has the Dual Gate Hurst shifter but it doesn't seem to work or more likely I don't know how it works.
I can't seem to move it to the right thru the gate?
HELP
bundy is offline
Old October 27th, 2014, 09:52 AM
Mr. Johnson
rjohnson442's Avatar
Did you push the metal shield over to access the 1-2-3? ? It should move over in neutral to the other side with very little pressure.
rjohnson442 is offline
Old October 27th, 2014, 10:37 AM
bundy's Avatar
It doesn't seem to move
bundy is offline
Old October 28th, 2014, 02:47 PM
Mr. Johnson
The shield or the arm on the shifter? its just a little spring that holds it to the left side your pinky should be able to move it over to the right. if not I'd suspect something is jammed in the shifter (pen old receipts junk...) somewhere. Or someone put a dual gate plate on a regular shifter but I don't even think that would work.
Old October 28th, 2014, 02:51 PM
Mr. Johnson
does it look like this?
Old October 28th, 2014, 03:05 PM
bundy's Avatar
Yes it does. They rebuilt the tranny and it is really stiff even pulling it down out of park to drive. I suppose they didn't get it in right but they are out if vegas and the car is in sd now.
bundy is offline
Old October 28th, 2014, 05:04 PM
Mr. Johnson
If its hard to move into any gear it might be the steering column binding or the parking lock. You should be able to look down into the shifter while it's in park to see if somethings stuck down there. Really in a perfect world this is all something the shop should of fixed replaced or made you aware of. did they put in a new shifter cable to?
Old October 28th, 2014, 06:17 PM
Octania's Avatar
distach the backdrive [trans up to steering column] underneath and see if it works better. If so, it's the steering column or backdrive.
If not, look at the shifter and/or the CABLE and its connections.
Octania is offline
Octania
January 31st, 2015 04:54 PM
1983oldsmobiledelta
October 7th, 2010 02:55 PM
mudjnky
January 14th, 2009 08:02 AM
Quick Reply: Dual Gate shifter, how does it work?
