69 cutlass 350, modulator pipe
Old Apr 25, 2022 | 01:50 PM
lala5818's Avatar
I have a 69 Cutlass S convertible. Original 350 V8 with the original Turbo 350 tranny. Is there a particular vacuum nipple that I need to connect the modulator pipe to? I had a Holley 4BBL 650 installed on the motor with an Edelbrock intake. There's a small vacuum nipple at the very bottom of the Holley at the front of the carb. It's not the large vacuum nipple on the back. I assume that ones for the brakes.
front of carb
Old Apr 25, 2022 | 02:17 PM
Any full manifold vacuum source (not the timed/ported source) will work.
Old Apr 25, 2022 | 03:20 PM
The port on this runner is where the factory connected the vacuum modulator. On my car, I just swapped the nipple from the original iron manifold to the RPM manifold. Made connection easy and I didn't have to bend the modulator hard line.
lala5818
Jan 29, 2022 08:33 AM
rr69ho
Dec 8, 2013 05:44 PM
thatguy32567
Jun 4, 2009 06:35 AM
cutlass cool
Oct 8, 2008 10:22 AM
Chris Browning
Sep 17, 2008 12:08 PM
