200r4 finally awaited
Old Jun 13, 2026 | 02:54 PM
Southstar's Avatar
I have been wanting to do this for 10 years, since installing 3.73 rear gears. That was the plan. Newly arrived Extreme Automatics 200r4. PTC 9.5” 2500 torque converter. Getting my stuff together to put it in this fall. Car now has TH400 and stock converter so this should get the old G block up quicker. .224 duration Lunati cam needed more converter for sure. Has 285 /40/18 rear tires so it should get motivating with the converter for sure. This was the best 200 they offer . I am upgrading the u-joints to 1350 series so the pinion yoke is.562”longer, along with a new transmission yoke the TH400 driveshaft will be the right length for the 3/4” shorter 200r4. I think it’s going to work well with the mild cam locked up in 4th gear at 45 mph or so without lugging.
Could always upgrade to a 455 engine but the 400 is not too bad for my need of speed these days. At least I can break the transmission in with it and make sure the 250 lbs. line pressure doesn’t eat the thrust bearing in the engine.
Extreme automatics 200r4 ready for the fall.
Old Jun 13, 2026 | 03:09 PM
Southstar's Avatar
Tell me what you think.
I don’t have a dipstick yet. Was going to see if the th400 tube would work . Maybe remark the full line?
Old Yesterday | 04:03 AM
BlueCalais79's Avatar
You are going to love that new 200R4 from Extreme Automatics, they did one for me 2 years ago and it's been a great deal. Nice choice!
Old Yesterday | 07:18 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
With a better stall and first gear, it will be quicker off the line. With the lock up and and .68 OD gear, you will drop 1000 rpm on the highway. The 2004R, when built strong enough, has a really nice gear spread and a perfect OD ratio for aggressive rear gears. You will like it a lot.
Old Yesterday | 08:41 PM
bccan's Avatar
Pretty sure your present dipstick tube will work. I have always used TH350 tubes & indicators wiithout issue. I’m not sure if TH400 is different.
I have a G Body tube & stick that I just put in my scrap bin, they will not work in an A Body. I will however take some pics of measurements & post them so that you can compare your 400 parts.
Old Today | 10:49 AM
bccan's Avatar
Old Today | 12:03 PM
Southstar's Avatar
Thanks, bccan for the photos.
If the 400 tube doesn’t work, I could resort to an aftermarket flexible tube .
Interesting that the g-body 200 tube doesn’t fit . I had the idea of trying to find one of those. Glad you mentioned that and saved me the trouble.
Mikes 75Delta88
Oct 10, 2023 02:06 PM
philv1983
18
Jul 10, 2023 08:31 PM
Bw1955
20
Feb 4, 2021 08:45 PM
redbaron442455
Apr 4, 2020 10:22 AM
Phoenix8990
Dec 3, 2019 06:26 PM
