1964 Oldsmobile Hydra-Matic Bell Crank
Old Oct 24, 2019 | 09:54 AM
bccsrc's Avatar
I have this bell crank that I need to make work with dual carbs. This first picture if for reference.
Thanks to Charlie Jones, I have one of these now.
Seems like I might be able to get this working if I was able to modify the part below to fit on the rear carb.
Old Oct 24, 2019 | 10:48 AM
What kind of multi-carb intake do you have? The part you're looking to modify is supposed to fit under a 2 barrel carb (maybe the Rochester 2GC) while the last pic shows a 2x4 intake.
Old Oct 24, 2019 | 11:23 AM
bccsrc's Avatar
Offenhauser. That part gets the bell crank in about the right position. It would have to be modified to mount onto the back stud of the rear carb. I'd only use about this much of it:
oldsw31
Oct 22, 2019 09:16 AM
rummer
Mar 22, 2019 05:49 PM
BGVISTACRUISER
Oct 1, 2017 03:34 PM
gbledsoe3
Mar 30, 2017 07:06 AM
Gary M
Nov 23, 2016 04:06 AM
