Where can i find a replacement transmission?
Old Jan 11, 2021 | 08:16 AM
Billy33s's Avatar
Hey guys
My 1970 olds cutlass Transmission took a dump on me last year and I ended up selling the tranny out of it because it was no good But I realized I screwed up because I can’t seem to find another one anywhere.
I tried to buy one off of jegs and they ended up canceling my order after 5 month of waiting so I’m stumped, The car isn’t original at all someone put a Chevy 355 in it and the trans was a oldsTh350 short tail shaft that was adapter up to the block.
I’d love to get it back going again and I was wonder what aftermarket transmission would be a direct swap can I go with a Chevy th350 and it would boot Right up or would I need a olds trans because of how short the trans was Any help would be appreciated
Old Jan 11, 2021 | 09:17 AM
Welcome.
The transmission needs to fit the engine family.
Your looking in the wrong places. Chevy transmissions fit Chevy engines. A transmission from a Olds will fit a Olds, in addition to a Pontiac and Buick. All things considered there are 3 times more BOP cores available than Chevy stuff.
It would help knowing what transmission you need. Th350? Th400? Short or long output shaft?
Find a core, any transmission shop worth a dime can build a decent 350/400 trans cheaper than buying one from summit or JEGS. Where are you located?
Old Jan 11, 2021 | 09:31 AM
If your running a Chevy engine then you can use a Chevy transmission without the adapter plate.
Old Jan 11, 2021 | 09:56 AM
Charlie Jones's Avatar
Phantom Phixer
Most of the TH 350's of this era had a dual pattern on the trans face .
They had extra holes for either pattern .
They would bolt up to a BOP or a Chevy block .
Old Jan 11, 2021 | 11:10 AM
The TH350 is the most common GM trans available from the aftermarket. EVERYONE sells them. Summit, Jegs, Speedway, TCI, B&M, Jasper, etc, etc.
Old Jan 11, 2021 | 02:02 PM
Billy33s's Avatar
I have the short tail shaft i believe it’s really small and stubby and I measured it out to be about 6 inch where the yoke is. So would any tran th350 that had a short tail shaft in it work or is there a specific one?
because I had a truck th350 out of a 80s Square body with a short tail and it was a few inches off so I’m not that familiar with trans so is there a difference between car and truck transmission and that’s why it’s off or is it something else I think i have a pic of the original trans I’ll posted it below
Old Jan 11, 2021 | 02:06 PM
The truck version is the longest TH350. Most car applications are the shortest one.
Old Jan 11, 2021 | 10:54 PM
Grayghost's Avatar
It should not be hard to find a check th350 short tail.
remove the adapter plate and bolt in the chevy th350.
sell the adapter plate..
Old Feb 18, 2021 | 07:18 PM
425HP409's Avatar
Restorer
Agree...
Old Feb 18, 2021 | 09:05 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Old Feb 21, 2021 | 08:24 AM
70442rag's Avatar
If you need a short tail shaft (OLDS) Turbo 400 trans (beefier trans than the T350) I can help. I have several cores available for $175.00 plus shipping.
Good Luck.
Regards,
Brad
68cutlassdriver
24
Mar 20, 2021 04:33 AM
CJG
Aug 14, 2016 08:21 PM
HKanada182
Jun 2, 2014 10:38 AM
coppercutlass
Aug 4, 2013 07:21 PM
cutlass72
Jan 2, 2004 05:26 PM
