what are my tranny options mating to my 394
Old July 15th, 2009, 08:03 PM
64rocketman's Avatar
alright i know there are several threads on trannys that will mate up to a 394 with an adapter kiit
but im not sure if ive found all options
i would like to start with if it is possible to have a working set of lightning rods with a tranny that will mate up with an adapter kit
id like to know how to go this route what tranny to use as im pretty sure the 200r4 might not be the wisest choice as i plan to beef up the motor
what other 4 spd auto trannys are there that lightning rods will work with
that there are adapters to mate to a 394 ????
64rocketman is offline
Old July 16th, 2009, 07:17 AM
d2_willys's Avatar
WTH is a lightning rod? Depending on what year Olds you have (I take it 64 with Roto-hydramatic 10 (slim jim)) you could bolt a dual coupling (jetaway) hydramatic or the older dual range (two band) hydramatic. The older dual range hydramatic would not have the PARK position, but park is buried in R with engine off. Other than those, you will need some sort of adapter. Check with Ross Racing, they are making a pretty nice adapter for the TH400.
Get a hold of Tony at Ross Racing Engines. He has TH400/350's Made for the early rocket engines. He also makes aluminum heads.
d2_willys is offline
wr1970
March 29th, 2015 05:36 AM
July 5th, 2012 09:34 AM
trackz man
December 13th, 2010 12:45 PM
daverbmxer
May 24th, 2006 06:18 PM
west tenn. 1
May 5th, 2004 04:16 PM
Quick Reply: what are my tranny options mating to my 394
