"turbo hydramatic 350" = 350cui?
Old October 15th, 2010, 02:58 AM
sbstr's Avatar
hey,
im facing some trouble with my reverse gear, yet do i have a manual for my 1975 cutlass supreme with the 350 v8.
however, the manual sports four different transmission systems, namely 350, 375, 400, 425.
how do i know which one of those is built in my car? is there a relation to the displacement of 350 cubic inches in the transmission's name?
greets,
sbstr
sbstr is offline
Old October 15th, 2010, 06:07 AM
There is no relationship between the displacement of the engine and the type of transmission, at least not in the way you are thinking.
If I had to bet money, I would say that your car has a TH 350. Only because it has a SBO and it's a 1975 Cutlass. However, someone may have swapped a TH 400 into your car for one reason or another.
The easiest way to identify your transmission is to look at the transmission pan.
This is what a TH 350 transmission pan looks like:
http://www.summitracing.com/parts/SUM-433885/
This is what a TH 400 transmission pan looks like:
http://www.summitracing.com/parts/SUM-433884/
Of course, the stock pans aren't as deep and they won't have ribs machined into the bottom side.
Olds64 is offline
81 regency
April 21st, 2011 06:18 PM
80_cutlass
March 17th, 2011 06:03 PM
Liegekiller
15
June 27th, 2009 07:58 PM
Liegekiller
May 30th, 2009 05:31 PM
Quick Reply: "turbo hydramatic 350" = 350cui?
