transmission Question
You current shift quadrant will only let you access Drive and Second. If you want to be able to manually get to first, you'll need to install a modified shift quadrant. Shiftworks sells this part for the factory floor shifters.
(Oldsmobile also made the earlier Jetaway 4 speed automatic, which is a very different beast)
If you are refering to the 2-speed Jetaway, used in 64-69 Oldsmobiles, then yes, it is pretty much a drop in. Of course there will be some issues, such as the shift quadrant indicator. The driveshaft may be another.
