Trans temp sensor location on 200 4r?????
Old February 29th, 2012, 09:46 PM
84hurst's Avatar
I've just ordered an autometer trans temp gauge and was wondering if the 200 4r would have a place to screw in the sender??
84hurst is offline
Old March 1st, 2012, 07:06 PM
oddball's Avatar
Drop the pan and drill a hole in it from the side. Make sure the sensor doesn't hit anything when it's fully installed.
oddball is offline
Old March 1st, 2012, 08:20 PM
84hurst's Avatar
Thanks! thats kinda what i've been hearin, So i wonder if i need to weld a nut inside the pan for the sensor to screw into or could i just thread a nut on and use some sort of gasket?
84hurst is offline
Old March 2nd, 2012, 05:20 PM
Vistabrat72's Avatar
I have seen 'Tee's' that will splice into the 'hot' oil line coming out of the transmission cooler line going to the cooler. In fact I have one that goes with an old B&M trans temp kit I plan on installing one day. The oil going to the cooler line is the top one in the 200-R4, contrary to most other GM automatics. Splicing into the line gives you the instant temperature coming out of the converter, but the pan mount gives you a nice overall transmission temperature. Howie
Vistabrat72 is offline
Old March 2nd, 2012, 08:51 PM
oddball's Avatar
When I've installed similar, the sensing unit installs with a nut inside the pan and includes a gasket. The instructions with your sensor will tell you what to do.
oddball is offline
Old March 3rd, 2012, 08:31 PM
84hurst's Avatar
Oddball: what brand gauge did you use? I have an autometer and the sensor only has a threaded end (no nut or gasket), But it seems like it'd be easy enough to find a nut and some sort of high temp rubber gasket i suppose.
84hurst is offline
Old March 4th, 2012, 01:39 AM
oddball's Avatar
It's been a long time since I messed with one. You might find some oil drain plug gaskets that are the right size.
oddball is offline
Old March 10th, 2012, 07:41 AM
68conv455's Avatar
CK performance told me to mount mine in the trans cooler return line.
I installed a tee just before the trans.
68conv455 is offline
Old July 15th, 2012, 07:07 PM
Redog's Avatar
How accurate is the tee fitting for temps?
Redog is offline
Old July 16th, 2012, 07:56 AM
'87 Delta 88 Royale
rustyroger's Avatar
I don't agree with that.
All that will tell you is how well the trans cooler is working, I would put the sensor in the oil pan. My reasoning is I want to know the overall temperature of my transmission, oil straight from the cooler sending line is likely to be hotter than in the transmission, in the return line it should be cooler.
How hot the oil being sent to the clutch packs etc is the information I want.
Roger.
rustyroger is offline
54oldz
June 20th, 2012 07:13 PM
coppercutlass
March 18th, 2012 06:02 PM
scott_442
February 22nd, 2011 05:26 AM
Aceshigh
October 1st, 2010 10:35 AM
cormike
Aurora
January 4th, 2009 07:30 AM
Quick Reply: Trans temp sensor location on 200 4r?????
