Trans "screech" when in reverse
Hi...Paul here. I have a '68 4-4-2 with a recently rebuilt automatic trans. When I start the car and put it into reverse it sometimes makes a loud screeching sound - the only way to describe the sound - it is similar to a starter grind when you turn the ignition when a motor is already running. It makes that bad noise when I go into reverse. I have this problem more often when the engine is cold. Any help would be very much appreciated. Thanks.
W-27
May 11th, 2014 05:41 AM
81 regency
April 21st, 2011 06:18 PM
