Trans "screech" when in reverse
Old Aug 28, 2015 | 08:27 AM
NJ442's Avatar
Hi...Paul here. I have a '68 4-4-2 with a recently rebuilt automatic trans. When I start the car and put it into reverse it sometimes makes a loud screeching sound - the only way to describe the sound - it is similar to a starter grind when you turn the ignition when a motor is already running. It makes that bad noise when I go into reverse. I have this problem more often when the engine is cold. Any help would be very much appreciated. Thanks.
Old Aug 28, 2015 | 08:29 AM
lemoldsnut's Avatar
I don't have help for you but have the same issue on one I had built a few years back. This will get me updated when someone helps.
Larry
Old Sep 1, 2015 | 05:34 PM
NJ442's Avatar
Can anyone recommend a good transmission shop in North New Jersey (Mossris County area)? Thanks,
ksukasiose
Sep 17, 2014 06:07 AM
W-27
May 11, 2014 05:41 AM
WasteOfMind00
Apr 15, 2007 06:37 PM
WasteOfMind00
Apr 12, 2007 06:38 AM
