Torque Convertor Clearance Issues
Old Oct 7, 2023 | 11:29 AM
ajr2820's Avatar
So I went to install my new torque convertor and when doing so, there is minimal clearance to the flexplate. It will move freely, but is definitely rubbing. The TC seems to be seated properly. I have tapped with a mallet and it seems to be solid. I am only getting 7/8" clearance from the pad to bellhousing when it should be ~1-1/8" clearance. It appears to theoretically have room to move back before it hits the pump, but I can't seem to get it to move. I am definitely turning the pump and have tried moving it 180 degrees and seating in alternate tabs, but get the same result. Measurements from the new TQ match the old so it is not that. Transmission has been totally rebuilt by me a year or 2 ago. Any thoughts on what I might have assembled incorrectly to cause this? Any tips on getting the TQ to sit back another 1/8-3/16"? I'm running out of ideas here.
Old Oct 7, 2023 | 02:52 PM
Sugar Bear's Avatar
Could the flexplate be on backward? I don't recall if that is even possible or if it is offset.
If the converter wasn't all the way seated the bell housing wouldn't have mated flush to the engine block. Did it mount up flush without being drawn in with bolts?
Did the converter jump back inward two times while rotating it?
Old Oct 7, 2023 | 02:55 PM
Sugar Bear's Avatar
What model transmission?
Old Oct 7, 2023 | 04:58 PM
It isn't possible to put the flexplate on backwards
Old Oct 7, 2023 | 05:37 PM
BillK's Avatar
Are you certain they didnt make the converter for use with a midplate ? That makes the pads about 1/8" to 1/4" taller.
Old Oct 8, 2023 | 06:18 AM
ajr2820's Avatar
Problem solved. Input shaft was bottoming out before fully seated. I ground @1/8" off the taper on the input shaft. All good now.
tmatador
Aug 26, 2021 07:17 PM
86odls
Mar 25, 2014 06:08 AM
bigwillystyle
Nov 13, 2010 11:52 AM
lionelbob
May 27, 2010 08:10 PM
olds455
May 17, 2010 04:43 PM
