Torque Converter Seating Issue
Old Sep 11, 2013 | 07:44 AM
88hurstolds's Avatar
www.gbodyolds.com
Having issues getting a TH400 torque converter to seat onto the input shaft.
Seems to be a tapered bulge on the input shaft to allow a press fit of sorts :?: never seen this before.
The TC will slide onto the shaft but will only be flush with the bellhousing and not recessed to allow the flex plate to sit inside the housing.
I did have the notched key-way lined up with the key.
I tried to torque it down on the engine to see if it will pop in but it sits way too tight and I am afraid I might crack the bell housing.
I've never ran into this issue with TH350's or TH2004R's...
The trans is a PR TH400 from a '76 Grand Prix SJ going onto a '73 Olds 455 from a Custom Cruiser all into a '72 Cutlass Supreme.
The trans does have a single wire coming out of it, is this for a switch pitch converter?
Are TH350 TC's interchangeable with TH400's?
I am wondering if I was given the wrong TC but I am almost positive this is the right one since my dad pulled it just recently.
It has a number 4 stamped around the perimeter if that matters...
TIA
Old Sep 11, 2013 | 09:32 AM
Octania's Avatar
The single wire is for kickdown on a TH400
Two wires can be for that plus SP or that plus Trans Controlled Spark Bullshed [TCSB]
Sounds to me like all your parts should be compatible. measure and verify that the keyway things are sized to mate properly. Turn a lot. Yes, the 350 & 400 TC's are interfittable.
Maybe make sure you do not have part switch pitch and part not.... google for the Buick "how to tell" page?
Old Sep 11, 2013 | 11:04 AM
stan 65 cutlass's Avatar
you have too spin it, sometimes quite a few times to seat it, if its like other ones ive done
Old Sep 11, 2013 | 11:19 AM
www.gbodyolds.com
I spend about an hour messing with it by spinning it, pulling it out slightly, lining up the keyway etc...
I guess I will keep at it.
Going to ask my pops if he grabbed the wrong TC by accident, it's possible the keyway is mismatched.
Old Sep 11, 2013 | 01:37 PM
The first time I ever installed a converter into a TH400, it took me about an hour. The last fifteen minutes involved sitting on the suspension crossmember and cussing at the trans. That apparently did the trick.
Also, note that you often need to pick up on the converter as you push inward and spin it to get the splines and pump drive tangs to all engage simultaneously.
Old Sep 11, 2013 | 03:25 PM
www.gbodyolds.com
Noted, thanks.
I am going to hang the trans vertically with the engine hoist and work at it.
I've never experienced this with any other trans (TH350 and Th2004R) and I've swapped quite a few...
Old Sep 11, 2013 | 03:44 PM
Octania's Avatar
Evidently, it's your turn to agonize now...
Old Sep 11, 2013 | 09:26 PM
BILL DEMMER's Avatar
Just the facts...
a 4 stamped into the convertor? like this?
^^^^ that's a switch pitch convertor, it aint gonna fit a non-switch pitch thm400.
bill
Old Sep 12, 2013 | 07:43 AM
www.gbodyolds.com
Yes it has a 4 stamped on it like that but they are all facing the same direction and not alternating like that.
I am going to check to see if I was given the wrong converter.
Old Sep 12, 2013 | 09:18 AM
Octania's Avatar
There are difference you can easily learn to spot
Just find that Buick info page, with photos.
Old Sep 12, 2013 | 09:35 AM
www.gbodyolds.com
Couldn't find it and I am pretty good at searching for things on the internet...
Perhaps a link?
Old Sep 12, 2013 | 04:28 PM
RetroRanger's Avatar
72 Olds CS
http://www.buickperformanceclub.com/switchpitch.htm
http://www.442.com/oldsfaq/oftsp.htm
Old Sep 13, 2013 | 05:43 AM
www.gbodyolds.com
Thanks for the links!
Wound up being a switch pitch converter.
5 out of the 6 I had were all switch pitch converters, would you believe that!
Old Sep 13, 2013 | 07:21 AM
TripDeuces's Avatar
"Wound up being a switch pitch converter.
5 out of the 6 I had were all switch pitch converters, would you believe that!"
Hold onto them!
Old Sep 13, 2013 | 07:57 AM
oldsguybry's Avatar
NOVICE car nut
This is one of the reasons I'm afraid to put my 455 in my CS . I never messed with a TC before , and I personally know someone who put there TC on wrong and ended up with a big broken mess as a result of it .
65 Delta Guy
Aug 12, 2012 06:30 PM
oldsmobilia
Jan 18, 2009 05:48 AM
oldsmobilia
Jan 18, 2009 05:40 AM
54olds
Mar 31, 2008 06:07 PM
Oldsmofjord
Jul 30, 2007 04:58 AM
