water entering the seating compartment
Old Jul 10, 2007 | 09:18 AM
Oldsmofjord's Avatar
after heavy rainfalls, water keeps getting in and dripping where you rest your feet in the front. Don't know where to begin looking so I can neutralize this irritating problem...
It's the Cutlass LS sedan 1981
Old Jul 14, 2007 | 12:22 PM
okay
so I suspect this is a drainage problem - it may be clogged somewhere, but my problem is where on earth I should start lookin'
Old Jul 14, 2007 | 02:53 PM
Originally Posted by Oldsmofjord
okay
There's a rubber drain hose on the bottom of the A/C box on the engine side of the firewall. Frequently leaves and debris will get in though the cowl opening and eventually clog this drain. The water has noplace else to go but inside.
Old Jul 15, 2007 | 02:48 AM
allrighty, will check it out !
Old Jul 30, 2007 | 04:58 AM
Jim's rare 80's Avatar
Jim's rare 80
If the water is coming in on the passenger side, it is the AC box seal. You will have to remove the wipers, and lower stainless trim to get at it. I used a spray-on seal called "stop leak." Let us know if this works. Jim.
kitfoxdave
Mar 31, 2013 12:38 PM
Moses
Oct 6, 2010 07:22 AM
oldsmobilia
Jan 18, 2009 05:48 AM
oldsmobilia
Jan 18, 2009 05:40 AM
54olds
Mar 31, 2008 06:07 PM
