Tightening TH350 trans cooler lines on 72 cutlass
Old April 21st, 2018, 10:22 AM
Chris
Oldssupreme's Avatar
Hi! Stupid question, but How in tarnation am I supposed to attach my transmission lines to the transmission? I don't seem to have any room to turn the line wrench. Was I supposed to do this with the transmission out? Maybe I need a ratcheting open ended wrench for this? Should I drop the exhaust head pipe?
Thanks!
chris
Oldssupreme is offline
Old April 21st, 2018, 11:36 AM
I do the top one first before installing the lower one.
oldcutlass is online now
Old April 21st, 2018, 11:45 AM
Chris
Ok, let me try that. And you leave your exhaust head pipe installed?
Old April 21st, 2018, 05:33 PM
Chris
Ok. Thank you. I tried that and it worked. Only issue was that each turn of the line wrench only got me about 1/16 of a turn and then I'd flip the wrench and get another 1/8" and etc. took about an hour to do both lines I want to go back and do animal tightening if i can. Thanks!
chris
Old April 21st, 2018, 07:07 PM
If I can't snug it by hand, I use ignition wrenches to turn the fitting snug and tighten with a line wrench.
Old April 24th, 2018, 06:28 AM
SmirchIs#1's Avatar
chris
Glad you reached your goal.Going to suggest another method for the final tightening for anyone to add to their arsenal of tactics.You can purchase a crows foot version of a line wrench,which used on the end of an extension works well for me.Many times you must use a wobble extension to get the crows foot square on the nut,which is important so you don't round the nut
SmirchIs#1 is offline
Old April 24th, 2018, 01:06 PM
Chris
Smirchls thank you. I didn't realize they made a crow foot version of a line wrench. Any brands you recommend? So if I put a long extension you're thinking I will be able to get much more movement per turn?
Chris
Old April 24th, 2018, 02:47 PM
mrolds69's Avatar
Crow foot line wrenchs are great tools. Really expensive to buy from the good tool companies though, for what little you use them. But you can buy a cheap set and they will work. One thing they are REALLY good for is the power steering hoses on the box. You get like a 3 foot extension and it makes that job really fast, easy, and you can get them nice and tight. Good for fuel pumps, too.
mrolds69 is offline
Old April 24th, 2018, 03:37 PM
Chris
Thanks son much for the advice! Much appreciated!
Old April 24th, 2018, 04:57 PM
72 Olds CS
RetroRanger's Avatar
Hey Chris I just searched Amazon and found a good variety of offerings for crows foot line wrenches w many sets under $50
I likes new tools so I added a set on my wish list
Crowfoot and crows foot searches give different results so try them both for best results
RetroRanger is offline
Old April 24th, 2018, 05:25 PM
Chris
I likes new tools too RetroRanger! Dropping $300 at the docs office makes me irritated but somehow I don't mind buying new tools for the same! Thanks guys!
Chris
Old April 24th, 2018, 07:07 PM
mrolds69's Avatar
I know everybody hates Chinesium, but this is the kind of thing that's good to buy at Harbor Freight. $11.99 a set, on a rack, -20% with a coupon...SAE or Metric. I have mostly Snap on crow foot line wrenchs. ONE of a size like say 9/16" costs more than a complete set of metric AND SAE on racks from HF. Maybe they aren't as strong, or a perfect fit, but for what little you use them...they are a good deal!
mrolds69 is offline
67Rocket
February 2nd, 2016 07:12 PM
Tony72Cutlass'S'
April 7th, 2013 05:28 PM
rocketraider
December 1st, 2011 03:51 AM
68conv455
January 3rd, 2009 11:53 AM
bjtstarfire
December 13th, 2008 08:48 PM
Quick Reply: Tightening TH350 trans cooler lines on 72 cutlass
