TH400 Valve Body
Old Nov 10, 2024 | 12:55 PM
OLDsBARRY's Avatar
TH400 Valve Body
1971 w30 OW trans
manual valve body ?????
Old Nov 10, 2024 | 01:57 PM
Here's one that's automatic/manual. I'm sure you could get a full-manual valve body with transmission brake too if you wanted it.
https://www.summitracing.com/parts/tci-222400tci
FWIW, I considered putting a full-manual valve body in my 86 Ford F250 since it's a diesel and the vacuum modulator metered orifice is no longer manufactured. Instead I had the Vacuum Regulator Valve (metered vacuum orifice) rebuilt by the one supplier available online. After a C6 rebuild the transmission shifts like a champ.
Old Nov 10, 2024 | 03:19 PM
70W-32's Avatar
Originally Posted by OLDsBARRY
1971 w30 OW trans
If youre asking if it came that way from the factory, then no.
It would have come with higher shift points, and the ability to hold the gear longer when manual shifting.
But should operate as normal when left in the drive position
Old Nov 12, 2024 | 01:59 PM
The OW valve body is kinda unique. The OW and Buick Stage 1 BB calibration are the same, this has been discussed at length on the V8buick forum.
What specifically are you wanting to know? If your wanting to convert to a manual/auto valve body, it’s a fairly easy modification if your comfortable removing the valve body. If you want full manual, it’s a little more involved but is easy enough.
Either way, if you are SURE you have a OW valve body, I’d suggest finding another valve body to modify.
montvaleplace
Apr 21, 2019 07:36 PM
Carl Elliott
Oct 31, 2017 07:14 AM
ferndaleflyer
Jan 29, 2016 11:23 AM
Charly9g
Jun 28, 2015 11:23 AM
boondocker
Aug 8, 2011 05:59 PM
