th400 trans fluid
It's between 10-12 depending on your converter. I would put eight in and then start it up and let it get warm while moving the gear selector through the positions. I don't recommend driving it until it's full. Once warm begin checking it and keep in mind that the fill line is a pint not a quart. I just went through this with my TH400 swap. Hopefully you don't have leaks like I did
cfair
Brakes/Hydraulic Systems
June 8th, 2009 12:37 AM
