th400 trans fluid
Old Jul 9, 2011 | 12:57 AM
1968ragtop's Avatar
th400 trans fluid
How much trans fluid does a th400 take? The trans is bone dry right now.
Old Jul 9, 2011 | 03:44 AM
joe68h/o's Avatar
If takes 9 qts to fill a tubo 400 and convertor if both are empty.
Old Jul 9, 2011 | 03:54 AM
You will keep pouring it in, and looking under the car because it MUST be leaking out somewhere. Just keep pouring.
Old Jul 9, 2011 | 06:42 AM
TripDeuces's Avatar
It's between 10-12 depending on your converter. I would put eight in and then start it up and let it get warm while moving the gear selector through the positions. I don't recommend driving it until it's full. Once warm begin checking it and keep in mind that the fill line is a pint not a quart. I just went through this with my TH400 swap. Hopefully you don't have leaks like I did
Robertoho
Jul 2, 2012 03:59 AM
Stevec
May 22, 2012 05:29 PM
ls442
Nov 11, 2010 10:45 PM
cfair
Brakes/Hydraulic Systems
Jun 8, 2009 12:37 AM
DAN76
Mar 25, 2009 08:26 AM
