th400 slow 2-3 shift
Old Jul 22, 2017 | 06:45 PM
truckman5000's Avatar
W30
Hey, hope someone can help me.
I have a th400 auto from 1970 its a rebuilt unit.
Reverse and selecting gears ( if car isnt moving) are very positive.
Ive adjusted the modular vacuum can on the side of the trans all around from too much vacuum were it shifts high, to were it wont shift out of 1st.
Im at a loss, as at the best setting ( shift points) the transmission is sluggish as its not slipping into gear, its not a crisp shift.
Trans has about 1k miles on it, and it has always acted this way. I drove it abunch because i was told by the trans. shop it needs to be driven...I just dropped the pan to do a fluid/ filter and there was just a tad of fine junk on the magnet.
Old Jul 22, 2017 | 07:04 PM
In my experience the modulator changes the shift points very little. I've also found that if your turn the screw inside too much cw it will fall through and not work correctly afterward. I have a transgo shift kit and a 2800 stall with 308 gears. It will shift really early under light load but when you get on it will shift where its supposed to.
Old Jul 23, 2017 | 08:07 AM
W30
Thanks, Eric looks like ill install a shift kit
Old Jul 23, 2017 | 05:37 PM
If it's a stock rebuild it probably does shift kinda mushy. Trans-Go is a good brand, there are a couple different performance levels that can be installed.
Old Jul 23, 2017 | 06:03 PM
W30
Another question, maybee this is why it shifts bad.
Its a ow w-30 trans. that i dont know what was done to it being rebuilt. Maybee it has the wrong kit or possibly wrong valve body?
Because say you put the "his" shifter on 1st, it will automatically shift to second.
So i see a auto/ forward manual kit im assuming that would be for a his/ her shifter?
pcard
Sep 4, 2024 02:13 PM
TRW
Jan 21, 2011 05:38 AM
ls442
Nov 11, 2010 10:45 PM
wolskara
Sep 15, 2010 10:03 PM
wolfman98
Site Help
Nov 19, 2009 05:06 PM
