Th400 with short tail, what driveshaft to use..
hello, im going to put in a newbuild heavyduty custom superturbo powered 400 transmission but it have 3" tail and my th350 have about 6,5" tail of the transmission there the driveshaft goes in to the shaft.
Just Wonder if is it an opinion of driveshaft out there to use instead of cut and weld it longer the driveshaft i have now. AND can i still use the stock transmission crossmember without modify it cause of the shaft?
My car is a b body 79 delta 88.
Thanks for Ideas.
Thanks for Ideas.
Thanks for Ideas.
Thanks for Ideas.
Aha, ok i tought they have the same yokes, I can see if i can find something used
Maybe i will just made a new from a driveshaft dealer and finish balanced,,but it is expencive..
Are th350 and 400 using the same size of crossbearings? I will check my local amcar store,i think they selling yokes there.
You won't find the correct length driveshaft that also has the correct yoke unless someone built it custom. The correct length factory driveshaft was used on the 200-4R applications and will have the small yoke. You'll need to get a TH400 yoke separately and swap it out.
TRW
January 21st, 2011 05:38 AM
64 CUTLASS KEN
November 22nd, 2010 05:17 PM
