TH400 to Rocket 350
Any particular reason your considering that? A TH350 is a very capable transmission behind a small block and is lighter. Someone please confirm/refute, I think the TH350 also has a lower first gear ratio for better acceleration???
well my current th350 is bad, and it’s cheaper to just buy a new one. I was under the impression that a th400 had better acceleration, but maybe that’s wrong?
If replacing the transmission I assume you'll be replacing the torque converter. Figure out your rear axle ratio and anything you know about your engine so that members with experience can guide you on the optimal converter stall speed. Don't rely on whatever "comes with it" as you may be needlessly leaving some performance on the table at not much expen$e.
Flush the cooler and lines, it's critical.
Good luck!!!
Good luck!!!
There's a reason you don't see this swap very often.
The TH400 has a HIGHER first gear (2.48 vs 2.52) so acceleration will be marginally worse. As I noted above, you'll be hard pressed to feel or measure the difference, which is 1.5%.
Supposedly, all things being equal, a car with a 400 trans will run about a tenth quicker with a 350 trans. This is due to much lighter internals, the overall lower weight of the 350, and due to the 400 consuming more powe just to operate.
You would need a VERY stout 350 engine to stress a properly built TH350 trans
I put a 455 from a 69 Toro in a 73 Omega in the early 80's. I was looking for a Turbo 400 to go behind it, and working on figuring out the modifications needed, etc. A friend had a salvage yard and said why don't you try a Turbo 350? He sold me one out of a 76 Cutlass or something, not rebuilt about 80,000 miles on it. Never did go back and install a T400. Withstood a lot of spirited driving behind that 455. Turbo 350's are pretty tough.
As said, a properly built TH350 should hold up, every shop can build them. I bought a nice 76 Cutlass for $50, it was parked with 120,000 miles due to the TH350 failing. Our 75 also died, both behind a whooping 165 hp. Nothing special with GM's mushy calibration. You have 3.42 gears, correct? Seriously consider a mildly built TH2004R, it will drop highway rpm by 1000 rpm with lock up. It also has a 2.74 first gear with a good gear spread. Pick a 2000+ stall with your cam, no matter what trans you pick.
The TH350 gear ratios are 2.52, 1.52, and 1:1
The difference in 1.6% in first and 2.6% in second. You will not be able to feel that, no matter how finely tuned your butt dyno is.
I seriously doubt it would even show up on a chassis dyno. Those figures are within the e we indie of repeatability.
The difference in weight and power consumption would probably show up on a timeslip, but not the “butt-o-meter”. While I’m sure it’s be done, I’d be curious to see a back to back chassis dyno test.
If I were the OP I wouldn't worry about the 1.5% or my butt dyno. The cost of the installation will be a few hundred bucks more unless he gets the parts for free or really cheap. If he is planning on a bad *** 455 later there is no reason to go with the turbo 400.
