th400 long shaft??
th400 long shaft??
I have a th400 in my 69 cutlass parts car, I think its a long tail shaft (tail is about 9" long) Should I put this long shaft trans in my 68 convertible or look for a short shaft transmission. Can the rear shaft be replaced with a short tail shaft?? TIA
I'm not sure if its the long shaft. The tail shaft is about 9" long, does that sound like a long or short shaft?? The car its in is a 69 2 door cutlass and it has a driveshaft in it, so it should swap into my 68 no problem. I didn't know a long shaft would even fit in these cars. Can anyone tell me how to identify if its long or short shaft??
TIA
TIA
So apparently the long shaft th 400 does fit into a 2 door cutlass, so I'm looking for opinions on if this is a good idea or if it would be better to find the short shaft th 400? Is there any difference internally other than being longer??
No, and in fact, at work we convert them in under an hour. The one you have is a medium shaft. The longtail is 12" and only used in Cadillacs.
If it fits in your car and you have a driveshaft for it, then you should have no problems using it. Or, you can swap the output shafts and covers.
Since the output shaft is the last thing out and the first thing in to the trans case, I assume that in an hour you are simply pulling all the internal parts out and putting them back in without any parts replacement other than the output shaft. I'm (unfortunately) a MIGHTASWELL guy, so if I've got the trans that far apart, I MIGHTASWELL rebuild it.
Also, if you are having a hard time finding a short tail output shaft and housing, let me know. Give me the year and spline count and I can find one for you.
L77F85
October 1st, 2013 07:16 AM
64 CUTLASS KEN
November 22nd, 2010 05:17 PM
