th400 long shaft??
Old Mar 29, 2011 | 08:58 PM
1968ragtop's Avatar
th400 long shaft??
I have a th400 in my 69 cutlass parts car, I think its a long tail shaft (tail is about 9" long) Should I put this long shaft trans in my 68 convertible or look for a short shaft transmission. Can the rear shaft be replaced with a short tail shaft?? TIA
Old Mar 29, 2011 | 11:33 PM
svnt442's Avatar
It is a long process to change the tail shaft. The trans would have to be completely disassembled to get it out. It would be easier just to find a short tail trans and be done with it.
Old Mar 30, 2011 | 03:31 AM
If it's already in a Cutlass, shouldn't it be a short shaft (I could be wrong here)? Or did you modify it to fit when you put it in?
Old Mar 30, 2011 | 05:22 AM
Rickman48's Avatar
If the parts car has a driveshaft in it, just switch both.
[if it's a 2-dr]
Old Mar 30, 2011 | 08:24 AM
1968ragtop's Avatar
I'm not sure if its the long shaft. The tail shaft is about 9" long, does that sound like a long or short shaft?? The car its in is a 69 2 door cutlass and it has a driveshaft in it, so it should swap into my 68 no problem. I didn't know a long shaft would even fit in these cars. Can anyone tell me how to identify if its long or short shaft??
TIA
Old Mar 31, 2011 | 11:31 AM
1968ragtop's Avatar
After looking at my th400 s.p. trans.... this one is definately a long shaft.
Old Apr 1, 2011 | 07:46 PM
1968ragtop's Avatar
So apparently the long shaft th 400 does fit into a 2 door cutlass, so I'm looking for opinions on if this is a good idea or if it would be better to find the short shaft th 400? Is there any difference internally other than being longer??
Old Apr 10, 2011 | 05:32 AM
kgenesse's Avatar
No, and in fact, at work we convert them in under an hour. The one you have is a medium shaft. The longtail is 12" and only used in Cadillacs.
If it fits in your car and you have a driveshaft for it, then you should have no problems using it. Or, you can swap the output shafts and covers.
Old Apr 10, 2011 | 09:16 AM
Since the output shaft is the last thing out and the first thing in to the trans case, I assume that in an hour you are simply pulling all the internal parts out and putting them back in without any parts replacement other than the output shaft. I'm (unfortunately) a MIGHTASWELL guy, so if I've got the trans that far apart, I MIGHTASWELL rebuild it.
Old Apr 10, 2011 | 09:20 AM
kgenesse's Avatar
No, we rebuild the unit in that hour. haha
Old Apr 10, 2011 | 11:24 AM
1968ragtop's Avatar
Is it hard to find the short shaft tail and output shaft for these th400s?
Old Apr 10, 2011 | 05:03 PM
ziff396's Avatar
Really. You can properly disassemble, inspect parts, go through the valve body, replace all seals, bearings, clutches etc in 1 hour?? Along with the tail shaft?? Maybe the haha was a joke.
Old Apr 10, 2011 | 05:31 PM
kgenesse's Avatar
No, we do them in an hour. Assuming they are on the bench when we start. Disassembly is all done with air tools. We take everything apart and throw it in the washer for 10 minutes and that thoroughly cleans everything. The heat makes the seals easily removed, and we just pluck them off and install the new ones as we go. A TH400 shouldn't take very long for a professional rebuilder. The new stuff is what ties up the bench.
Also, if you are having a hard time finding a short tail output shaft and housing, let me know. Give me the year and spline count and I can find one for you.
Old Apr 10, 2011 | 09:11 PM
1968ragtop's Avatar
kgenesse... where are you located?
Old Apr 11, 2011 | 02:54 AM
kgenesse's Avatar
Live in Rhode Island, work in Massachusetts. It is likely that we have a short shaft and housing on the shelf at work.
L77F85
Oct 1, 2013 07:16 AM
dfire25
Aug 31, 2013 08:21 AM
64 CUTLASS KEN
Nov 22, 2010 05:17 PM
Schober Motorsports
Oct 20, 2009 07:08 PM
442much
Jan 30, 2009 04:58 PM
