TH400 Gear Noise from transmission sound
Old Jan 6, 2015 | 11:30 AM
delta_88_germany's Avatar
TH400 Gear Noise from transmission sound (video)
hey
few weeks ago when it startet to beeing cold i have a strange noise from the transmission (engine) as you can hear in the 2 videos it sounds like 2 gears running bad.
also then its cold it takes 5 sec between a gearchange in N to R or N to D
1. noise is louder when engine cold.
2. when warm sound nearly dissapear
in Video 1 you can hear it in N (loud) after switching to D it dissapears nearly and while driging faster it comes again
seems like it hast something to do with the input shaft of the transmission.
first i thought of flywheel and starter gear that seem the origin of the sound while try to hear and identify it.
(N then switch to D )
(while driving with 20 mph)
any thoughts ?
Old Jan 6, 2015 | 12:41 PM
don71's Avatar
same but different
My first impression when viewing the video, it might be your speedometer cable.
I have experienced gear whine with my th400 as well. In the same way you describe it, when it gets cold.
Lets see what the other guys think.
Old Jan 6, 2015 | 12:55 PM
I dont think that it can be thecable because the Noise is proportional with The engine rpm not the vehicle Speed ...
Old Jan 6, 2015 | 02:23 PM
It sunds like the pump or gears that drive the pump. Pump could be struggling to make pressure. Is it low on fluid? When was the last time it had a filter change?
Old Jan 7, 2015 | 12:18 PM
hey Eric
thanks for your thoughts, i checked oil level in P while engine running and warm -> OK and clear.
i dunno when filter was changed the last time think more than 5 years ago.
if the filter blocks the oil this also can occur the bad shifting when cold...
i have oil and a filter set in tha garage bought a month ago i ll chenge both and keep u posted...
Does anyone know how much should be filled in when empty ? TH400 6 quarts ? right ?
Old Jan 10, 2015 | 01:59 PM
So Filter and oilchange Done -> Noise gone;-)
Attached a pic of the pan the oil was clear but in the bottom of the pan was a lot stuff
Is that normal?
Old Jan 10, 2015 | 04:28 PM
Its hard to tell what you had going on in the pan as you wiped it. Normally there would be piles of clutch material and other stuff under the filter. Does it shift ok now? Glad it worked out, you may be close to an overhaul in the future, so save your money.
Old Jan 10, 2015 | 10:17 PM
don71's Avatar
same but different
I've been told a spoon full of material is normal. Probably read it in a car magizinge. but what kind of spoon? how big?
Like Eric said, you'll probably be fine for now but things could get worse. Its hard to tell .
Old Jan 11, 2015 | 01:23 AM
It Shifts normal...
But i dont Know when was the Last time a Filter change was made.... Can be 10 yrs ago....
I Own the car 2 years...
Old Jan 11, 2015 | 01:34 AM
nsnarsk65cutlass's Avatar
Looks like lack of servicing,good luck.
Odmark
26
Apr 12, 2013 06:27 AM
terrapin
Feb 5, 2013 09:10 AM
ragtop70
Sep 3, 2012 10:15 AM
61reoldsman
Aug 2, 2012 06:58 PM
Wyze
Sep 28, 2010 06:37 PM
