TH400 dipstick leak
TH400 dipstick leak
I have a pesky leak on my TH400, on a '69 Vista. After the car sits, the fluid appears to leak where the filler tube enters the case. I've replaced the O ring, and tried securing it with 'great stuff' gasket maker. Still no luck. Any suggestions for a newbie ? I've tried to pick up a new filler tube, but only found non-Olds ones that are the incorrect shape. Thanks
You might try to look under 69 Cutlass for parts like this. These kind of parts would be used on both Vista and Cutlass.
Here is a few link for places that sell parts.
http://www.thepartsplaceinc.com/ocat...&YearList=1969
http://www.fusick.com/cutlass.htm
http://www.paddockparts.com/Paddock/...B67FBFCD5BC2E4
http://www.yearone.com/
Kaz , I am going to test your theary today when I refill the trans with fluid,
I had the same leak and redid it like you described , so it gets refilled today , but I wont be able to test drive yet. If it still leaks I will get a newer style tube with the rubber grommet instead of the oring , then it will be leak proff.
dantecl
October 27th, 2013 02:50 PM
Flye
August 10th, 2009 06:23 AM
