TH400 dipstick leak
Old Apr 2, 2010 | 06:07 PM
FrankChandler's Avatar
Question TH400 dipstick leak
I have a pesky leak on my TH400, on a '69 Vista. After the car sits, the fluid appears to leak where the filler tube enters the case. I've replaced the O ring, and tried securing it with 'great stuff' gasket maker. Still no luck. Any suggestions for a newbie ? I've tried to pick up a new filler tube, but only found non-Olds ones that are the incorrect shape. Thanks
Old Apr 2, 2010 | 07:24 PM
70 cutlass s's Avatar
You might try to look under 69 Cutlass for parts like this. These kind of parts would be used on both Vista and Cutlass.
Here is a few link for places that sell parts.
http://www.thepartsplaceinc.com/ocat...&YearList=1969
http://www.fusick.com/cutlass.htm
http://www.paddockparts.com/Paddock/...B67FBFCD5BC2E4
http://www.yearone.com/
Old Apr 3, 2010 | 05:56 AM
kaz442's Avatar
New O ring and some silicone will work just have to clean the tube and the hole really good with some brake clean on a rag so the silicone will stick. JKaz
Old Apr 3, 2010 | 06:25 AM
MJAKS462's Avatar
Kaz , I am going to test your theary today when I refill the trans with fluid,
I had the same leak and redid it like you described , so it gets refilled today , but I wont be able to test drive yet. If it still leaks I will get a newer style tube with the rubber grommet instead of the oring , then it will be leak proff.
Old Apr 4, 2010 | 12:10 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I tapped it and plugged it. Same with the speedo gear and the detent. All 3 of those are luxury items.
I do enjoy the luxury of a drain plug though.
Old Apr 7, 2010 | 04:52 AM
Oldsguy's Avatar
Past Administrator
J, you are living on the wild side. No speedo or way to check transmission fluid levels? Wow.
Old Apr 7, 2010 | 10:15 AM
It's like a differential now.
I put a deep sump pan on it, and fill until fluid runs out the hole.
dantecl
Oct 27, 2013 02:50 PM
Jolly Green
Jan 16, 2013 05:07 PM
TRW
Mar 22, 2011 05:15 PM
Gunfreak25
Mar 14, 2011 07:34 PM
Flye
Aug 10, 2009 06:23 AM
