TH350 Vacuum Line
Old May 9, 2021 | 05:29 PM
dre's Avatar
dre
TH350 Vacuum Line
Fluid level seems to be where it should be, kickdown cable is correct. I have the car up on jackstands and trying to see if the car is shifting in gear properly. If the modulator vacuum line is not connected, will it cause it to not shift and wheels to not spin?
Old May 9, 2021 | 06:02 PM
If the modulator line is not connected, the trans will think you are at wide open throttle and will hold the trans in first until you hit about 5,000 RPM or so. Then it will upshift hard. Nothing about the modulator will prevent the trans from shifting into first or reverse, however.
Old May 9, 2021 | 06:19 PM
dre's Avatar
dre
Thank you Joe. What do you think is going on then?
Old May 9, 2021 | 08:09 PM
If the wheels are not turning, make sure the trans is actually shifting into gear. The linkage may be disconnected.
Old May 9, 2021 | 08:45 PM
dre's Avatar
dre
Linkage is connected. I shifted into R,N,D and checked under neath to make sure it was connected and shifting properly. Is there anything else I need to check?
Old May 9, 2021 | 08:53 PM
With so little background info it’s hard to diagnose.
Could be the filter is clogged or not inserted so it’s not drawing fluid.
Shift pawl could be disconnected from the linkage ear.
Fluid pump could be shot.
Could be a valve body issue.
Lots of possible failures.
Old May 9, 2021 | 08:58 PM
Is your parking brake on? Is the torque converter bolted to the flexplate? Make sure neutral allows you to turn the driveshaft by hand.
Old May 9, 2021 | 09:33 PM
dre's Avatar
dre
The torque converter is connected. I had driven it up on the trailer about 7 years ago to transport to a storage facility. Went to move it again about 3 years ago and it then didn't accelerate when I put it in drive. Patience is running thin. Thinking about ordering a new tranny or having this one rebuilt.
Old May 9, 2021 | 09:38 PM
Did you check the fluid level with the engine running? Is the fluid a pretty red color or brown and stinky.
Old May 9, 2021 | 09:40 PM
dre's Avatar
dre
Yes. It was red.
Money72
23
Dec 24, 2019 07:32 AM
oldsguybry
22
Jan 8, 2018 10:44 PM
at3reg98
Jun 27, 2012 06:27 PM
Homestar
Apr 3, 2011 05:54 PM
455Gbody
Aug 24, 2009 11:45 AM
