th350 to th400 swap
th350 to th400 swap
Hi guys. I am looking to convert my th350 transmission to a bigger th400 for my 455. Will the floor shifter on the th400 fit correctly the console of my car as it was on the th350? Or any modification of the console should be done?
The shifter is bolted to the floor and nothing needs to move. Even the cable is the same.
What you do need to worry about is the parking brake cables because they mount to the crossmember. The cables are different lengths depending on the transmission due to the different mounting location of the crossmember.
Repro brackets are readily available.
