TH350 Slip Yoke Weep Hole Leak
Hi,
While the topic of what the weep hole is in the slip yoke of some TH350’s has been covered, my question is more on the proper fix. I see there are many suggestions to plug it, weld it or JB it. I’d like to fix it properly if I can. Is it safe to deduce that if I have the weep hole in my yoke then I have the output shaft that has the metal sleeve and the o-ring, rather than the yoke with the missing spline? I don’t want to purchase parts for something that isn’t applicable. I also don’t want to pull the yoke and have the car sit while I order parts.
Does anyone have a lead on what the proper part number/retailer that I can pick up the proper o-ring from?
