B&M lockup controller for 200r4
I have a 84 olds 98 and I got rid of the ccc carb and distributor and I have a lockup kit from b&m to install but upon reading the instructions that came with it I read that on some early computer controlled tcc trans you have to go into the valve body and remove a spring in the tcc valve train. I am assuming 1984 is a model year where u would have to do this. My question is can u get to this with just dropping the pan or would I have to take the valve body down? I have zero experience with the inner workings of an automatic trans so i might just do the wiring myself and then take it to a trans shop to have them remove that spring
