TH350 Problems
TH350 Problems
My 67 started acting up this week, it does not down shift when stopped or slowing down. I can manually shift into first and it will go through gears on it's own. I was just under the car and was going to pull governor and see if it was stuck or if gear was shot but I am not sure there will be enough room to pull it. I have never removed one but I know I need to tap a driver under the edge to release the cover and then pull it straight out. In my car it is sitting center above the cross member and there is only about 3" of space between cap and where floorboard dips down. Is that enough room to slide it out? Also looks like it could be a PITA to get cover back on trying to tap edges of cover down with no room to work. Thanks for any help
I actually moved the line from ported to manifold when I changed my carb a couple of weeks ago. The metal line PO installed runs all the way up near front of motor so I used about 1 1/2' of rubber vacuum hose. I did plan on cutting metal line back to use shorter hose but did not think vacuum would be my current problem. Doesn't the modulator just control the upshift?
Ok back out to the driveway with crossed fingers, would be nice if it is just a vacuum problem. Eric thanks for everything you do here, I know I do not post often but I am on here everyday reading and appreciate all the great info and the time you and others take to help people like myself.
I had this happen to me last summer. Made the mistake of hooking it up to ported vacuum on carb on accident. Ported and manifold ports were rate next to each other. I made it a couple blocks and realized something wasn't rite. Hopefully that's all it is for you.
