TH350 Problems
Old May 12, 2016 | 11:59 AM
nj67's Avatar
TH350 Problems
My 67 started acting up this week, it does not down shift when stopped or slowing down. I can manually shift into first and it will go through gears on it's own. I was just under the car and was going to pull governor and see if it was stuck or if gear was shot but I am not sure there will be enough room to pull it. I have never removed one but I know I need to tap a driver under the edge to release the cover and then pull it straight out. In my car it is sitting center above the cross member and there is only about 3" of space between cap and where floorboard dips down. Is that enough room to slide it out? Also looks like it could be a PITA to get cover back on trying to tap edges of cover down with no room to work. Thanks for any help
Old May 12, 2016 | 12:09 PM
Can you remove the xmember and lower the rear of the trans and support it with a jack or something? Check your modulator and hose also, make sure you have good manifold vacuum on the line.
Old May 12, 2016 | 12:31 PM
nj67's Avatar
I actually moved the line from ported to manifold when I changed my carb a couple of weeks ago. The metal line PO installed runs all the way up near front of motor so I used about 1 1/2' of rubber vacuum hose. I did plan on cutting metal line back to use shorter hose but did not think vacuum would be my current problem. Doesn't the modulator just control the upshift?
Old May 12, 2016 | 12:36 PM
It controls both, and it needs manifold vacuum. When I was younger, I inadvertently hooked mine to ported and when it finally did downshift it bang like someone ran into the back of the car.
Old May 12, 2016 | 12:40 PM
nj67's Avatar
Dude you are fast Is it ok to have that much rubber line? I assume best way to check vacuum would be to pull hose at modulator and feel for steady vacuum.
Old May 12, 2016 | 12:42 PM
I don't think it will hurt as long as its not collapsing. You can also hook up a vacuum gage down at the modulator end.
Old May 12, 2016 | 12:47 PM
nj67's Avatar
Ok back out to the driveway with crossed fingers, would be nice if it is just a vacuum problem. Eric thanks for everything you do here, I know I do not post often but I am on here everyday reading and appreciate all the great info and the time you and others take to help people like myself.
Old May 12, 2016 | 12:49 PM
Hopefully it works.
Old May 13, 2016 | 10:03 AM
Did it work?
Old May 13, 2016 | 11:55 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
I have had the metal line plug up. The modulator could be bad too. If its bad replace it with an adjustable TM-50. The gov can be removed in situ.
Old May 13, 2016 | 02:35 PM
nj67's Avatar
I ended up getting distracted, now I won't have a chance to do it till Sunday.
Old May 13, 2016 | 09:06 PM
cwb442's Avatar
I had this happen to me last summer. Made the mistake of hooking it up to ported vacuum on carb on accident. Ported and manifold ports were rate next to each other. I made it a couple blocks and realized something wasn't rite. Hopefully that's all it is for you.
chasman414
Jun 25, 2020 07:05 AM
hunter
Dec 3, 2011 06:57 AM
Dave Ramos
Aug 1, 2005 05:56 PM
78Delta88
Sep 18, 2004 09:58 PM
cutlass72
Jan 2, 2004 05:26 PM
