TH-400 Vaccum Modulator
Old September 17th, 2008, 06:37 PM
65Delta88's Avatar
I have a stock TH-400 in my '65 Delta 88 w/ a 425, I was reading about a way to adjust the modulator and I was wondering how to go about it? Is there a screw inside where the vaccum hose goes? or is there another screw on the outside of the modulator?
65Delta88 is offline
Old September 17th, 2008, 11:54 PM
Registered
Bluevista's Avatar
I'm no tranny expert but the big original one I have on my '71 Vista with a Turbo 400 has an adjusting screw on the end and the hose connects on the side. The smaller new replacement type with the vac fitting coming straight out the end I have on another car has a little screw inside the vacuum fitting to adjust it. I seem to remember that there was an instruction sheet in the box that showed how to adjust it with a small flat bladed screwdriver.
Allan
Bluevista is offline
Old September 18th, 2008, 12:46 AM
Seasoned beater pilot.
J-(Chicago)'s Avatar
Stock factory modulators are pre-set and most are sealed. If you do have an adjustable one however,
turning the adjusting screw (found in the vacuum nipple) counterclockwise, you will lower the spring pre-load. This will cause earlier shifts. By turning the adjusting screw clockwise and raising the spring pre-load, the shift points will go up. The range of adjustability is only a few mph either way.
J-(Chicago) is offline
Old September 18th, 2008, 06:14 AM
Learn something new everyday!
Olds64 is offline
Old September 18th, 2008, 06:38 AM
d2_willys's Avatar
I have not worked on TH400 VM's, but Furd VM's have the adjustment, and it does control the shift points, but also increases pressure for firmer shifts too. I would think this may apply to TH400'S
d2_willys is offline
Old September 18th, 2008, 06:41 AM
65Delta88's Avatar
Thanks for clearing that up, I'll have to go and investigate this today and see what I can come up with.
Old November 10th, 2008, 01:42 AM
RoaringRelic's Avatar
Vacuum Modulator
The Vacuum Modulator controls the modulator valve which raises or lowers modulator pressure. The Modulator pressure will then effect both the line pressure and the governor shift point.
RoaringRelic is offline
Old November 24th, 2008, 11:24 AM
65Delta88's Avatar
How do I go about pulling the old one out? is it just pressed in? I have my new one and from the looks of it, I think it is just pressed in with an o-ring.
Any info??
Old November 24th, 2008, 01:50 PM
Past Administrator
Oldsguy's Avatar
I think there is a clamp similar to the way the distributor is secured, one bolt holds the clamp down tight on the modulator valve.
look here
Oldsguy is offline
Tom442
July 11th, 2013 12:38 PM
FAZ442
July 12th, 2012 06:04 AM
ztim
June 14th, 2009 07:49 AM
1972_442
March 17th, 2008 11:40 PM
a6m5zerosen
January 14th, 2008 05:11 PM
Quick Reply: TH-400 Vaccum Modulator
