TH-400 Vaccum Modulator
Old Sep 17, 2008 | 06:37 PM
65Delta88's Avatar
I have a stock TH-400 in my '65 Delta 88 w/ a 425, I was reading about a way to adjust the modulator and I was wondering how to go about it? Is there a screw inside where the vaccum hose goes? or is there another screw on the outside of the modulator?
Old Sep 17, 2008 | 11:54 PM
Bluevista's Avatar
Registered
I'm no tranny expert but the big original one I have on my '71 Vista with a Turbo 400 has an adjusting screw on the end and the hose connects on the side. The smaller new replacement type with the vac fitting coming straight out the end I have on another car has a little screw inside the vacuum fitting to adjust it. I seem to remember that there was an instruction sheet in the box that showed how to adjust it with a small flat bladed screwdriver.
Allan
Old Sep 18, 2008 | 12:46 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Stock factory modulators are pre-set and most are sealed. If you do have an adjustable one however,
turning the adjusting screw (found in the vacuum nipple) counterclockwise, you will lower the spring pre-load. This will cause earlier shifts. By turning the adjusting screw clockwise and raising the spring pre-load, the shift points will go up. The range of adjustability is only a few mph either way.
Old Sep 18, 2008 | 06:14 AM
Learn something new everyday!
Old Sep 18, 2008 | 06:38 AM
d2_willys's Avatar
I have not worked on TH400 VM's, but Furd VM's have the adjustment, and it does control the shift points, but also increases pressure for firmer shifts too. I would think this may apply to TH400'S
Old Sep 18, 2008 | 06:41 AM
65Delta88's Avatar
Thanks for clearing that up, I'll have to go and investigate this today and see what I can come up with.
Old Nov 10, 2008 | 01:42 AM
RoaringRelic's Avatar
Vacuum Modulator
The Vacuum Modulator controls the modulator valve which raises or lowers modulator pressure. The Modulator pressure will then effect both the line pressure and the governor shift point.
Old Nov 24, 2008 | 11:24 AM
65Delta88's Avatar
How do I go about pulling the old one out? is it just pressed in? I have my new one and from the looks of it, I think it is just pressed in with an o-ring.
Any info??
Old Nov 24, 2008 | 01:50 PM
Oldsguy's Avatar
Past Administrator
I think there is a clamp similar to the way the distributor is secured, one bolt holds the clamp down tight on the modulator valve.
look here
Tom442
Jul 11, 2013 12:38 PM
FAZ442
Jul 12, 2012 06:04 AM
ztim
Jun 14, 2009 07:49 AM
1972_442
Mar 17, 2008 11:40 PM
a6m5zerosen
Jan 14, 2008 05:11 PM
