TH 350 OR TH400
Old October 4th, 2009 | 11:06 AM
roscoep41's Avatar
TH 350 OR TH400
I have 71 cutlass s with a 350/th350. I just got a 1970 455 engine and would like to know if the th350 will hold up or do I need a th400.
Old October 4th, 2009 | 02:21 PM
svnt442's Avatar
It can be made to, but if it's stock it's not going to hold for long it you get on it at all.
Old October 4th, 2009 | 05:34 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
For some field data,
I've been running a th350 for 2 race seasons behind my 455, no problems yet.
It's a stock 71 cutlass th350 trans, and the car runs 13.1
However F-85 on this board blew up 2 th350's with his 455 that runs 12.8.
If you're going to run one, run an old one. The 1975 and later ones don't seem to hold up as well.
Old October 5th, 2009 | 06:45 AM
If you are removing the 350 to install a 455 then just put in a TH 400 while you are at it. Better to be safe than sorry.
Old October 5th, 2009 | 03:52 PM
roscoep41's Avatar
Thanks for the info guys. I think I will overhaul the th350 with a performance kit and try that. I dont drag only the occasional burn out.hopefully it will be ok if not I guess Ill need a 400.
Old October 5th, 2009 | 05:31 PM
Originally Posted by roscoep41
I dont drag only the occasional burn out.hopefully it will be ok .
You should be just fine if you're not running slicks.
Old October 5th, 2009 | 05:43 PM
f-85's Avatar
Wink
It was 3 th350s
Old October 5th, 2009 | 07:01 PM
Totally agree with Jesse. If you're going to have to rebuild or beef up the 350, why not go with the tranny that Olds put behind almost all of it's 455s?
Brook
July 8th, 2012 10:07 AM
70cutman
May 22nd, 2011 09:03 AM
TRW
January 21st, 2011 05:38 AM
ls442
November 11th, 2010 10:45 PM
deadmanscurve
March 12th, 2009 03:53 AM
Quick Reply: TH 350 OR TH400
