Tell me about these Jetaway transmissions
Unfamiliar with the 2 speed trans. Had a few Powerglides in 60's Chevys, but back then I only cared that my $75. 63 Impala got me there. I have read that others change to a 3 or 4 spd auto. Also hear about the switch pitch converter. My build is a 67 Cutlass conv. It will have the 320 hp 330 mostly stock engine and the 8.5" 12 bolt non posi rear from a 67 Supreme sedan. I have 2 Jetaways, the one from the parts car and the one from the conv, which came with the 250 hp and 10 bolt rear. Is there a difference? If I went with a 3 or 4 spd, how to convert the dash indicator?
Thanks for any info.
OK, I will play the devil's advocate here
I had a 64, 66, 67, and [maybe a] 69 with SB 2-bbl or 4-bbl and Jetaway Trans. Properly hooked up with switch pitch operating, they are serviceable and fun. Two speeds x switch pitch is like having 3 or 4 gears. Shifted out of 2nd at 60 with WOT. Very drivable. The '64 was a 4-bbl with presumably performance gearing [never checked for details but it felt fast]. The others were the usual granny gear final drive like 3.08 at best.
I tend to think that the attitude against the Jetaway comes from folks who do not have experience with a properly operating one.
If you go TH350 or the like, you will have to find the 442 type PRNDSL or fabricate your own. Might need the mechanism altered to allow enough travel at the trans as provided by the available travel at the shifter on the column or floor.
I have an all original 66 442 that the jetaway went south on and i opted to replaced it with a th400 and saved the original trans in storage. Its not as quick... with the heavy th400... as octania says jetaways are serviceable and fun. "Two speeds x switch pitch is like having 3 or 4 gears Shifted out of 2nd at 60 with WOT" , but put a shift kit in a good th350 and you will enjoy it too.
The Jetaway is actually a very durable transmission. It is nice to have more gears. But as already pointed out they do work great when set up and driven as they do have the switch pitch feature and it does work well. They are easy to find from us Olds guys and are rather inexpensive. Heck even you have two now. I think I have 5 of them all road tested.
The three speed shift indicators are available now and then. I might have one would have to check. They only came in column shift cars with a Th400 in 67 and that meant a 442, a turnpike cruiser or a Vista Cruiser with the th400 trans. So, a rather rare part.
A th350 is a direct bolt in swap. The shift indicator and kick down cable are the only things that really need to be addressed, it is also a good trans. A turbo 400 is a upgrade and will require more changes like: driveline change, and the shift indicator, crossmember moves back, but the linkage works and the cooling lines and electric kick down works as long as your kick down switch is good.
But, if all you are going to do is cruise with the car on the nice days and really be just a fair weather driver and car show stuff the Jetaway will work great.
Hope this helps
Larry
Hope this helps
Larry
There are three different TH350 tailhousing lengths. Only the short-tail is a direct bolt-in for the Jetaway. Same mount, same crossmember location, same driveshaft. This is a very common upgrade. You just can't beat a 2.52 first gear instead of 1.76.
Yeah,I think I'm sold on the 350. I think the biggest hurdle might be finding someone that could rebuild a Jetaway to specs. I'll bet your average tranny guy down the street might not have a clue. Only guy I can think of is in Calif., Manny T. who builds out switch pitch trannies for the GMC Motorhome (Turbo 425). Not building a hotrod, but the extra scoot could not hurt being I'm using the higher hp engine. I can find or fabricate something to give me a shift indicator. Hell, when I went to a GPS Speedo in my motorhome, I eliminated it completely. Not that hard to know where the gears are after some time. Thanks to everyone for their input, and if anyone near NE Florida area knows of a good one, let me know.
BOP to clarify means: (Buick, Olds, Pontiac) Chevy is the odd ball on bellhousing bolt pattern. The other thing to be aware of is that in the late 70's and early 80's they also used a lock up converter. Best just find a standard th350 from a 68-77 or so car. There are many out there. If you get desperate for one I have a few here but you should be able to find a few closer to you.
stocki26
January 25th, 2016 11:47 PM
Rocket Richard
August 22nd, 2012 11:37 AM
