Stupid bolt size question...
Old Jul 15, 2018 | 05:19 PM
Erinyes's Avatar
After an extended timeout, I'm finally ready to drop my engine and trans back in. Naturally a few miscellaneous bits have vanished in the meantime. Nothing major (knock wood), but I can't find the trans to block bolts, and I'd rather be sure on the size.
Anyone know the length of the six bolts? 425, TH400. TIA.
Old Jul 15, 2018 | 06:05 PM
3/8x16, probably 1 1/4 inched long
Old Jul 16, 2018 | 07:10 AM
oddball's Avatar
I've used closer to 2" grade 8 bolts. Use hardened washers. I'm not familiar with the 425 block but the others use all open holes with lots of space so you can use long bolts.
Old Jul 16, 2018 | 11:41 AM
edzolz's Avatar
All Olds engines use the same size bolts to mount the trans or bell housing to the block.
Old Jul 17, 2018 | 06:23 AM
No, they don't. Five of the six holes are through holes. The one near the oil filter adapter is a blind hole on all 1964-1990 Olds blocks.
Old Jul 17, 2018 | 07:41 AM
Chugger's Avatar
Can I jump in on this thread ? Same topic - different bolts. I have a 1965 F-85 wagon that someone put a chev 305 in with welded mounts. All of that is now removed and I'm installing an Olds 350. I have the frame pads - what size bolts do I need ?
Old Jul 17, 2018 | 06:26 PM
I’m guessing the people asking these questions are under 30 years old, long before the days when all you needed to work on these cars is a 7/16”, 1/2”, 9/16”, and 5/8” wrenches and sockets. That would cover probably 90% of the hardware on old iron! 😎.
To answef your question, once again 3/8x16 thread, probably 1 to 1 1/4 long.
Old Jul 18, 2018 | 06:57 AM
Chugger's Avatar
You forgot the phillips screwdriver :-) Thank you for the reply. Frame pads are in and its looking like an Oldsmobile again. Sorry for hijacking the thread. I simply couldn't think of a better subject line to ask my question. Oh ya. 1" is the perfect length.
Hawk1061
Jun 11, 2012 05:11 PM
droldsmorland
Oct 8, 2011 08:07 AM
louie
Sep 18, 2011 10:10 PM
Olds92
Oct 25, 2010 09:05 AM
oldzy
Oct 14, 2010 09:11 AM
