Stall Speed
Old May 21, 2010 | 04:52 PM
kenny's Avatar
Stall Speed
What are the benefits of a stall speed? I installed a 2500 TCI stall in my Trans Am and did not notice much of a difference. Comp Cams recommended it for a cam I was going to use. The cam was not used because you cannot use a roller set up with a egr intake manifold, stock or Edelbrock. Found that out the hard way. Any input?
Old May 21, 2010 | 06:07 PM
jensenracing77's Avatar
it is a little like holding the clutch on a manual till it is at a higher RPM them letting it go. it puts you in the engines power before it grabs.
Old May 21, 2010 | 06:28 PM
kenny's Avatar
Converter
So im assuming its ok and wont hurt anything to leave it in ?
Old May 21, 2010 | 06:35 PM
it won't hurt anything other than the extra gas that you use. the 2500 is not to bad but it will increase transmission temps for street use. i am not sure what stock is but my guess would be 1500 area
Old May 21, 2010 | 06:59 PM
442much's Avatar
I put a hi stall converter in mine about 20 years ago and hated it. I went back to stock. If I remember correctly my stock converter is a 2000 stall 12" converter. (Then again, I wasn't racing)
crank shaft
Aug 18, 2015 08:43 AM
johnnyjaws
Oct 26, 2014 06:57 AM
Billb442
May 22, 2012 04:43 PM
oldspower_68
Mar 20, 2012 08:43 PM
pcard
Oct 2, 2011 01:26 PM
