Stock stall speed
Old Aug 17, 2015 | 03:32 PM
crank shaft's Avatar
Stock stall speed
Can anyone tell me what the stock stall speed is on a TH350 from the factory? I tried to google it and find it here on the site with no luck,
Thanks,
Mike
Old Aug 17, 2015 | 04:03 PM
toymobile's Avatar
I have found 1500 - 1800 is normal, A lot depends on rear gear and front tire size.
Johnny
Old Aug 17, 2015 | 04:10 PM
wr1970's Avatar
Johnny
I think that is in the ballpark also.
Old Aug 17, 2015 | 04:36 PM
Yeah, I was told many, many years ago that "high stall" was 1800 RPM and the regular stall was ~1500 RPM.
Old Aug 17, 2015 | 05:30 PM
CutlassDad's Avatar
Stall speed is the engine RPM with the throttle wide open and the trans output shaft locked.
Old Aug 17, 2015 | 05:47 PM
bw1339's Avatar
Wouldn't stall speed be a function of whatever engine is bolted to that torque converter?
Old Aug 17, 2015 | 05:48 PM
wr1970's Avatar
I am sure this is about the converter as the op stated 350 turbo tranny.
Old Aug 17, 2015 | 08:30 PM
CutlassDad's Avatar
Yes.
Old Aug 17, 2015 | 09:22 PM
DING! DING! DING!
We have a winner. Stall speed of a given converter will be different depending on the engine in front of it. A 455 will stall that converter at a higher RPM than a 350. It has NOTHING to do with front tire size or anything else.
Old Aug 18, 2015 | 08:43 AM
GEARMAN69's Avatar
Typically a 12" TH350 is 1800 and a 13" TH400 is 1600 , thats is with a good amount of throttle and good strong rear brakes. I got 1700 out of stock TH400 with a 10.5:1 455
AZ455
Feb 19, 2013 08:21 AM
easytobedead
Nov 29, 2012 11:59 AM
65 Delta Guy
Sep 29, 2012 07:05 AM
pcard
Oct 2, 2011 01:26 PM
kenny
May 21, 2010 06:59 PM
