ST300 yoke
ST300 yoke
Hi ,im wondering if im gonna change my jetaway with a 200r4 or a short th350 would the yoke from the jetaway fit on those trannys? are those the same splines? i know that i have to relocate the trans.mount but how about the driveshaft? do i have to shorten it or is that a bolt-on?
Regards Panos
Regards Panos
Regards Panos
Regards Panos
The ST300, TH350 short tail, and 200-4R all have the same overall length and use the same driveshaft and yoke. The first two use the same crossmember position, while the 200-4R uses the TH400 crossmember position. Cars that did not have a TH400 option will need to have new holes drilled for the rearward crossmember location.
Ok thanks,im actually looking at this one http://cgi.ebay.com/ebaymotors/ws/eB...27525322610743 what do u guys think behind a mild 455?
