ST300 yoke
Old Mar 29, 2010 | 10:07 AM
panos's Avatar
ST300 yoke
Hi ,im wondering if im gonna change my jetaway with a 200r4 or a short th350 would the yoke from the jetaway fit on those trannys? are those the same splines? i know that i have to relocate the trans.mount but how about the driveshaft? do i have to shorten it or is that a bolt-on?
Regards Panos
Old Mar 29, 2010 | 10:52 AM
Regards Panos
The yoke and driveshaft are the same for the ST300 and the 200-4R.
Old Mar 29, 2010 | 11:03 AM
panos's Avatar
Ok thanks how about the short tail 350?
Old Mar 29, 2010 | 11:14 AM
firefrost gold's Avatar
Talking
I put a 350 in mine last year from a st 300 and I used the cross member and drive shaft yok and speedo gear. was very easy Or I got very lucky
Old Mar 29, 2010 | 11:21 AM
panos's Avatar
Sounds promising thanks
Old Mar 29, 2010 | 01:57 PM
The ST300, TH350 short tail, and 200-4R all have the same overall length and use the same driveshaft and yoke. The first two use the same crossmember position, while the 200-4R uses the TH400 crossmember position. Cars that did not have a TH400 option will need to have new holes drilled for the rearward crossmember location.
Old Mar 29, 2010 | 02:00 PM
panos's Avatar
Ok thanks,im actually looking at this one http://cgi.ebay.com/ebaymotors/ws/eB...27525322610743 what do u guys think behind a mild 455?
66cutlass
Nov 29, 2010 12:16 PM
66cutlass
Nov 28, 2010 07:16 PM
panos
Jan 10, 2010 07:18 AM
PAULIE
Oct 7, 2009 11:34 AM
RichardWilliams
Apr 7, 2009 08:18 AM
