Speedometer gear delete th350
Are there no speedo delete plugs for a 72 TH350? I seem to locate one for almost every other transmission on the planet except for one of the most popular ones?! So all of you running GPS speedometers, how do you handle this issue?
I ended up tapping the housing from the inside with a 1/8-27 pipe plug. Installed the plug with some red Loctite. I'll just find a rubber cap to clamp over the exterior portion where the speedo cable hooks in to clean it up a bit.
