Slim Jim
Old Jul 14, 2022 | 07:13 AM
jerbear2's Avatar
Slim Jim
Help Badley need a fill tube off a slim trans. Olds 1962- 88 .
Old Sep 2, 2022 | 09:38 AM
ripper27's Avatar
let me know if you still need fill tube , i'll check see if mine is still in truck of mine I swaped my slim jim foe a 350 chevy
Old Sep 10, 2022 | 04:47 AM
jerbear2's Avatar
Would you check to see if you have a filler tube. Sorry for getting back to this late.
Old Sep 10, 2022 | 06:27 AM
ripper27's Avatar
ok will do , the trans shop said they put all parts in trunk . Haven't gone there and looked yet . Will this weekend
Old Sep 12, 2022 | 12:51 PM
ripper27's Avatar
here's what I have , let me know if and what part you need , Tube and holding bracket for tube
Old Oct 13, 2022 | 07:37 AM
ripper27's Avatar
haven't heard from you , let ne know soon if you still want it , Thanks
Old Oct 15, 2022 | 10:14 AM
jerbear2's Avatar
I did reply but you must have not got it, anyway i got one. thank you for come back.
Old Oct 16, 2022 | 07:12 AM
ripper27's Avatar
Great ,
Old Jun 15, 2023 | 03:26 PM
BigAlD88's Avatar
BigAlD88
Where did you pur hase an adapter kit for the conversion?
Old Jun 16, 2023 | 06:48 PM
ripper27's Avatar
I got mine from Ross Racing in Ohio ,heres some post to look at https://classicoldsmobile.com/forums...lim-jim-17372/
https://classicoldsmobile.com/forums...2-olds-162113/ if you look up KQQLCAT they did a Ross Racing swap but to a 61 olds they said it was fairly easy . mine was done to a 62 olds very different and much harder . is not cheap but had no choice after 2 rebuilds on the slim jim could not get parts and nobody in my area know how to fix it , hope this helps
Old Jun 20, 2023 | 08:31 AM
Oldsfan's Avatar
KQQLCAT they did a Ross Racing swap but to a 61 olds they said it was fairly easy . mine was done to a 62 olds very different and much harder.
'61 and '62 full size cars use the same engine, transmission, engine/trans mounting and floor sheet metal. I don't understand what could be so different that the conversion would be so difficult - not that it's an easy conversion to begin with. If it was easy I'd have mine done by now.
Old Jun 20, 2023 | 03:17 PM
ripper27's Avatar
The frame is different which changes the installation, on the 62 you have to make a new crossmember ,believe me I found out the hard way , research it , I think there’s a 4 inch difference in the frames ,
Dgurkan
Jun 1, 2022 06:53 PM
dennis_30281
Jun 17, 2018 07:08 PM
Oldpac62
Nov 9, 2017 03:46 PM
Scott Allen
Jul 11, 2013 04:16 PM
DreWRoolZ
Sep 29, 2011 01:41 PM
