Shift linkage/cable help
Old Apr 6, 2021 | 09:05 PM
Reese Neis's Avatar
How is this clip suppose to be on here it’s a th400 trans and it’s for the actual shift cable itself
Old Apr 7, 2021 | 04:34 AM
boese1978's Avatar
Goes just about where you are holding it, between the bracket on the Trans and the rounded cable.....slides between the 2 and provides pressure to hold the cable in place.
Old Apr 7, 2021 | 04:55 AM
Rallye469's Avatar
I’m pretty sure that the side you’re holding to camera gets flipped around(to face forward in the car)
Thats the mating surface that pushes against the bracket and not the collar of the cable.
Just wedge it in a little and then tap it home with a hammer.
-peter
Old Apr 7, 2021 | 10:56 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Look at how the front brake caliper soft line mates to the hard line at the frame bracket. That same (or similar) retention clip resides there too.
Old Apr 7, 2021 | 11:05 AM
This pic shows which side the clip goes on. You can just see the corner. The 90* tab points out opposite the bracket facing the front of the car. It allows the ability to grasp with vice grips or similar tools for removal/installation. I usually tap them into place with a small ball peen.
projectheaven
17
May 21, 2015 09:22 AM
Rocket73
Aug 6, 2013 01:09 PM
dmberendsen
Jan 2, 2013 05:14 PM
ctrain22
Sep 7, 2009 10:54 AM
65f85
Jun 10, 2009 03:50 PM
